Glow Plugs!!!!
Old May 5, 2009 | 08:26 PM
GRECO's Avatar
GRECO
Glow Plugs!!!!
I am getting new glow plugs tomorrow. I am going with Motorcraft ZD-11. while under the VC's I am retorqing pedistal bolts and the hold down bolts and doing the .25 shims. What I need is a clear understanding of how to remove the wire from the top of the glow plug. I dont want to damage the connector. Does it unscrew or just pop off. I do understand about using a deep 10mm to loosen then use a hose to finish unscrewing it out.
Thanks for all the posts that are here on these topics. Megawatts and ponychris were a great help in deciding to do it myself.
Old May 5, 2009 | 08:49 PM
F350-6's Avatar
F350-6
The glow plug wire comes off just like an old fashioned spark plug wire. Just pull straight up to unplug it.
Old May 5, 2009 | 08:51 PM
GRECO's Avatar
GRECO
Really need to get the answer so I dont damage anything.
Thanks
Old May 5, 2009 | 08:52 PM
GRECO's Avatar
GRECO
F350-6 Thank You Thank You Thank You
Old May 5, 2009 | 09:04 PM
F350-6's Avatar
F350-6
Let us know how many bolts you find loose under there, and what kind of difference you notice after you torque things back down.
Are your glow plugs bad, or are you just changing them since you'll be under there? Those things don't tend to get as much exercise down here.
hondacrf450x
Apr 9, 2021 11:03 AM
84tanandbrown
Oct 4, 2014 04:13 PM
captgann
Dec 16, 2010 10:38 PM
bcbearcathunting
Jan 29, 2006 08:01 AM
tommy_rebel
Jan 26, 2002 05:15 PM
