93 ford explorer trans leak
Old May 5, 2009 | 07:13 PM
italianstallion's Avatar
italianstallion
She only does part time ? Cant tell if its coming out of the top of front seal, or torque converter. Any ideas ?
Old May 6, 2009 | 11:06 AM
mrshorty's Avatar
mrshorty
It's fairly common for the A4LD to leak from the front seal. Mine has done it twice under heavy loads (overheating the transmission). Make sure you are getting good flow through the transmission cooler (maybe need a heavier duty cooler). From what I understand, the front seal isn't too hard to change, as long as you don't mess with the pump.
Old May 6, 2009 | 11:21 AM
italianstallion
Thank You for your response. I checked the radiator cooler and previous owwner diconnected it, she was running on remote cooler only. I ran it back to the radiator, well see what happens today.
