Transmission temp sender...
Old May 5, 2009 | 02:45 PM
triskit16's Avatar
triskit16
Ive done a few quick searches and cant find the picture Im looking for. I think Im going to check dieselsite or dieselmanor for the pic.
Big question....
Teflon tape or teflon paste or neither on the threads on the sender?!
Old May 5, 2009 | 02:48 PM
superduty4x4's Avatar
superduty4x4
I installed mine dry, then ended up with a slow leak so I pulled it back out and taped it. It depends though- is your sender a single wire that grounds through the sensor, or a two wire sender? If its two wire- tape it up. If it's a single wire sender, taping it might not let it ground properly.
Old May 5, 2009 | 02:51 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
No tape or paste on mine. The tape will keep it from getting a ground and reading correctly.
Old May 5, 2009 | 03:11 PM
triskit16's Avatar
triskit16
Its a single wire...what if I do what dieselmanor suggests in this tech article...I dont want it to slowly leak on me!
3-Gauge Install Pictures
Thanks for the quick replies!
Old May 5, 2009 | 03:15 PM
megawatt00's Avatar
megawatt00
I used 1 wrap of teflon tape on mine with no problems. The tape will go to the inside of the threads and the outside will make contact for the ground.
Old May 5, 2009 | 03:21 PM
Ponyboychris's Avatar
Ponyboychris
Tape on mine as well. Single wire Autometer sensor. Never had a leak nor a bad ground reading in the three years on the truck.
Old May 5, 2009 | 06:02 PM
triskit16's Avatar
triskit16
10-4! Ill get it done tomorrow when it stops raining so I wont drown under my truck!
Old May 6, 2009 | 10:41 PM
triskit16's Avatar
triskit16
Update...
One wrap of teflon and it seems to be working fine. It was hard to get it up to temp today when it was only 60 or so out and my gauge doesnt start til 100!
