General Diesel Discussion
Help w/ disiel
Old May 5, 2009 | 09:17 AM
Extacie's Avatar
Extacie
Help w/ disiel
My friend was tellin me that disiel trucks engines last quite a bit longer than gas generally and I had a question. How are disiels for muddin compared to gas? Thanks, Tyler.
Old May 5, 2009 | 10:50 AM
Cuda_jim's Avatar
Cuda_jim
You will have all the torque you need with a diesel but the RPM's are a lot lower and they are slower to respond. Plus the diesel is heavier..probably not a good thing for muddin'
Old May 5, 2009 | 11:33 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I agree with Cuda_Jim..
-Enjoy
fh : )_~
Old May 5, 2009 | 12:03 PM
senix's Avatar
senix
8,000 lb truck is not the best to go thru mud.
Old May 5, 2009 | 12:12 PM
brian42's Avatar
brian42
Veteran: Navy
My rig (empty bed and full tank of gas and me in the driver's seat) is 7700lbs.
My front end alone is well over 4000lbs so it doesn't float too well...
Old May 6, 2009 | 08:39 AM
Extacie's Avatar
Extacie
lol alright thank you
Old May 6, 2009 | 06:05 PM
nevrenufhp's Avatar
nevrenufhp
Unless you have tractor tires, and you're the guy pullin everyone else out.
Old May 11, 2009 | 09:40 PM
Dually TAS's Avatar
Dually TAS
Not very good in sand either.
Old May 15, 2009 | 10:25 PM
Dean88's Avatar
Dean88
I got my 88 stuck, granted its only a 2wd, but unlike most 2wds that get stuck when the rear ends dig themselves gone, mine got stock I took a look and realized the rear wasn't sunk, but instead the front bumper was touching the mud, end I don't even have 4wd so the front end sank to that, not dug itself.
