Headlights surging ?
Old May 5, 2009 | 06:34 AM
jeeepxj's Avatar
jeeepxj
I've searched around some and will continue to search, but.. My headlights and actually all the dashlights surge. This happens at idle or going down the road. The alternator was just rebuilt about a year ago. Any thoughts? The voltage gauge in the dash seems to stay at a constant 14v. Do I have something that's about to go out?
Thanks
Craig
Old May 5, 2009 | 07:46 AM
Ponyboychris's Avatar
Ponyboychris
Don't have an answer but here's a bump.
Old May 5, 2009 | 07:48 AM
megawatt00's Avatar
megawatt00
If they brighten upon acceleration that that would lead me to beleive that the VR in the alt is not working properly. I would start by checking all of your connection both pos and neg, grounds to the frame and block and even the cables first.
Old May 5, 2009 | 10:54 AM
just another truck's Avatar
just another truck
But if they are pulsing at idle.. or while you are on cruise.. you have most certainly a Voltage regulator problem..
Old May 5, 2009 | 11:00 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Thanks
Craig
If that thing is any kind of accurate, then he may have a bad connection or short in the lighting circuit, most likely a ground somewhere. A good way to check this is with a good meter connected to the battery to see if that fluctuates when the lights do. I hate electrical gremlins. Good luck.
Old May 6, 2009 | 09:45 PM
jeeepxj's Avatar
jeeepxj
Thanks all. I've checked the cables already, but I'll double check those again and see if the voltage fluctuates at the batteries with the lights.
Craig
bigbadben
1997 - 2003 F150
Jun 15, 2020 03:42 PM
DSun
6.7L Power Stroke Diesel
31
Dec 29, 2014 01:31 PM
cajunsuperduty
Oct 28, 2011 03:31 PM
cjfarm11
79
Jan 27, 2011 11:26 PM
acousticbill
1978 - 1996 Big Bronco
Sep 9, 2003 10:26 AM
