The center bearing on my two piece driveshaft ('73 F-100) has a loose rubber cushion, causing my driveshaft to shake. I've done a lot of mechanics in my time, but never worked on one of these. What's necessary to swap out that rubber? Or do I have to swap out the whole support for a new one? Anybody have a diagram? The books don't make it very clear. Thanks, Polkat.
The rubber is part of the bearing assembly. The local parts stores should have one for about $15. They may even press the new bearing on for you.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,L&L Ladder Bars,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
1997 F350 PowerStroke 4X4,36 Inch Super Swampers, Strait Piped, Chiped, Propane Injected, LUK Clutch
