Nerfbar Install On Big White
Old May 3, 2009 | 09:43 PM
95F350XL's Avatar
95F350XL
Lol, so I mounted up my 20 buck universal step bars from the swap meet. 20 for the bars, and 10 in angle iron.
So I got lucky and the front mount didnt have to be made, it bolted right up to the cab pinch weld. I just had to drill 3 holes and bolt it up, I need to be up further, but I would have had to make a bracket and i think it looks fine like that.
Front Mount Drivers Side
Back Mount Drivers Side
Front Passanger
Back Drivers
The back mount took me a while to think up, but I started to cut some square stock and then it came to me. I used 5" of square stock, welded it to the tube mount, then got it where I wanted it, held the angle iron on the frame and tacked it to the square stock, took it down, full welded it, drilled 2 holes in the angle iron, and put it up, marked holes on the frame, drilled em out, and bolted it up. I will make some support tabs for where you step as my Westins on my F350 have them.
Old May 3, 2009 | 10:20 PM
Jeff Dodson's Avatar
Jeff Dodson
Sure looks like a nice truck and the bars look great as well
Old May 4, 2009 | 06:22 PM
95F350XL's Avatar
95F350XL
Thanks man, cant beat it. Just picked the truck up a month ago too.
