Sponsored by: Real Truck
Bad Vac Hoses
Old May 3, 2009 | 08:53 PM
dhead57's Avatar
dhead57
Bad Vac Hoses
Hi<O</O
I have a class A motorhome on a ford super duty chassis. I had code for the EGR valve. In checking this out I have found that most of the small vac lines the hard lines that are red, yellow green and black are brittle and snap easy. Is there anyone that knows if you can get a replacement set or an the be replaced with rubber or silicone vac hose it a 1997 7.5 liter (460) any help with this question would be great<O></O>
Old May 3, 2009 | 11:31 PM
ReAX's Avatar
ReAX
It's vacuum so any replacement hose will need to withstand the force of the pressure differential. However, yes, any hose that fit tightly over the nipples and not collapse under pressure then it will work.
