PCV Replacement help.
Old May 3, 2009 | 06:42 PM
jangelucci's Avatar
jangelucci
I am replacing the PCV in my 88 F-150 Custom, 5.0. The hose is not budging, so before I break something, like my knuckles, does any one have any tips. Thanks
Old May 3, 2009 | 08:28 PM
dustybumpers's Avatar
dustybumpers
just keep working on it until it comes off. the hose has dry rotted, and become hard, your going to have to replace it too. sometomes if you can get a pairof channel locks in there and twist/pull, etc. make sure you clean off the junk that stays behind when you get it off, before you put on your new hose
Old May 4, 2009 | 03:12 AM
jangelucci's Avatar
jangelucci
Thanks for the help, I had a tune up done on my truck and was surprised they didn't change the PCV. I just acquired this truck and I think that this is the original PCV, so i will change the hose too.
I always get positive feedback on this site, and appreciate the input from my fellow Ford lovers.
Old May 4, 2009 | 04:10 AM
John SCB's Avatar
John SCB
You'll be amazed at how your mileage, idle and passing smog checks improves. I replaced mine at 100k and should have done it much sooner.
