I have an E40D automatic with 55,800 miles on it and its been pretty well maintained,but I notice when it gets hot it jerks when you put it in reverse.Is this unusual? It otherwise works fine.
[updated:LAST EDITED ON 26-Sep-02 AT 00:43 AM (EST)]>if we new the application ie vehicle it is always easier to
>get an answer!
>it sounds like you could have trouble with the reverse
>clutch pack. are there any codes or light flashing?
>Jim
Have you dropped the pan and looked inside? I would suggest to do this and use a Ford trans filter. the after market filters drop down in the pan and cause the filter to suck air causing harsh shifts.
