Sponsored by: Auxito
Sloppy T-Case
Old May 2, 2009 | 07:29 PM
cdknechtel's Avatar
cdknechtel
Sloppy T-Case
I just pulled the front driveshaft off of my '02 F150 FX4 to replace a u-joint. While I was working, I noticed that the output shaft from the transfer case to the front axle has a considerable amount of slop in it (between 1/8th and 1/4 turn). Is this normal? If not, what kind of repair am I looking at?
Old May 2, 2009 | 08:51 PM
4DTech's Avatar
4DTech
If you are checking your front output shaft you will have some play unless your t-case is locked into 4wd.....
Old May 2, 2009 | 09:03 PM
cdknechtel's Avatar
cdknechtel
Out of four wheel the front output shaft will spin freely...the slop that I'm speaking of occurs while the transfer case is locked into four wheel drive.
Old May 2, 2009 | 09:18 PM
4DTech's Avatar
4DTech
Some free play is normal it is just a chain and like all chains they do stretch I wouldn't worry until you hear the chain hitting the case.... Very noticable noise.. Or replace the chain. Up to you....
Last edited by 4DTech; May 2, 2009 at 09:19 PM. Reason: Tired i need to go to bed....
