Driveline Vibes
Driveline Vibes
Greetings All-
Just picked up a '90 F350 2wd to replace my used-up van... nice shape, but has two issues that I have valiantly tried to cure but have come up short: The driveline vibrates badly -- the center support bearing was bad, and replacing it helped a lot, but it's still there at around 70 mph and up. The Haynes manual doesn't include info about the bushing at the back of the trans; could this be bad? The tires may be the culprit, but if so it'd be the most out-of-balance dually ever.
Related to that is trans fluid is leaking out the back of the trans as well, but not through the seal; instead it's coming out through the shaft and into the forward U-joint. Should there be a plug at the end of the splined shaft that slips in the trans? I'd guess this plug would have to be almost 2 inches in diameter.
Lastly, I replaced the pwr steering box (it was binding severely). It's all good except there's now huge play in the wheel. The paper that came w/ the new box said "don't adjust". The linkage that follows looks good, and while a friend moved the wheel, we verified that the play seems to be in the box. Should I adjust it anyway? Am I missing something?
Anyway, many thanks for any input.
Dave in Delaware
Dave in Delaware
Driveline Vibes
Hi Dave,
Check your driveshaft end yokes to see if they are line up with each other. Sometimes on a two piece driveshaft when the yoke is slid off the spline it is not always put back in the same place when reassembled. This is called " being out of phase". Also another thing to look at is the angle of the pinion shaft on the rear axle and the angle of the transmission u-joint. Both of these angles must be equal to each other or vibrations will result.As to the oil leak coming from the universal yoke, this may very well be true. I would check it out. Leverett Fernald
