Front frame rail?
Old May 2, 2009 | 02:17 PM
learpilot's Avatar
learpilot
Front frame rail?
I would like to move the front bumper back closer to the body and I would like to cut the frame rails off before I replace the boby but I don't know how much I can trim off, Could someone tell me how much of the rail is exposed between the back edge of the front bumper and the valance which is just behind the bumper ? Thanks
Old May 2, 2009 | 03:23 PM
mostly52f1's Avatar
mostly52f1
dont know if this will help, but i'll go thru sum diagrams i have to see if i can find you sum measurements. i cut my frame horns off, so i have nothing to messure lol.
Old May 2, 2009 | 05:54 PM
sjahnke's Avatar
sjahnke
On my 53 f-100 I have 3 1/4 " of exposed frame rail between the bumber and the gravel pan. Hope that helps >
Old May 3, 2009 | 10:32 AM
cmoritz's Avatar
cmoritz
If I remember crrectly ,I removed 2 1/2"..Here are a couple of tips/ideas/thoughts..
You may have to ' trim ' the upper bumper mount bracket to clear the openings in the gravel pan (try a mock-up fit..seems to me I ended up 'recessing' the brkt into the opening), also , if possiable, do any necessary drilling /welding /fabbing..before cutting the end of the rails off..again ,do a mock-up and keep a tape measure handy.I remember making a pattern of the holes in the framerail..top and bottom, and then just moving everything back the desired amount...I'm sure I have the details in my notes ...but it's buried like everything else,and like everybody else's projects,was done a long-time-ago..LoL! Good Luck! You will like the look of this mod!! ( consider the matching rear'snugger' brackets from Mid50)
Old May 3, 2009 | 02:08 PM
B/B ford's Avatar
B/B ford
Clean & Classy
On my 56 with the bumper "tucked" I have 1 1/4" of exposed frame rail between the bumper and gravel pan.
I didn't say how much I shortened the rails because I can't remember.
Old Aug 26, 2009 | 06:15 PM
jrzwalker86's Avatar
jrzwalker86
I have a 55' F250 that I am trying to rebuild the front of the frame. I bought it from a salvage yard with it torched off in front of the body valence, probably just to take the bumper. I'm looking for a set of dimensions that I can go by to rebuilt them. Does anyone know where to find them? Thanks in advance.
AcesHigh
27
Dec 12, 2019 02:12 PM
56exp
Jan 18, 2016 07:52 AM
56exp
New Member Introductions
Jan 16, 2016 03:23 AM
greg213187
Mar 2, 2010 06:08 PM
dwdubois
2004 - 2008 F150
Jul 15, 2005 01:21 PM
