Disabling 4x4 Help
Old May 2, 2009 | 12:34 PM
Rugby3's Avatar
Rugby3
Disabling 4x4 Help
I have a 2000 Explorer XLS with Control Trac. Just recently the 4x4 has engaged itself permanently. I have found the threads that recommend disconnecting either the brown wire into the TC or the wire harness itself. I have disconnected the harness and it is still engaged.
I have about 185,000 miles on it and am not interested in putting any more money into this damn thing. I was thinking of just removing the drive shaft to the front axle as now that I am down here in NC I don't need 4x4.
Any thoughts or other advice?
Thanks
Old May 3, 2009 | 04:24 PM
aquanaut20's Avatar
aquanaut20
Had the same happen to mine (18 months as 2 WD), run it without the front drive shaft, wont hurt anything.
When I finally cracked open my T/C, the locking cam on the clutch pack had lost one of its 3 *****.
Old May 3, 2009 | 05:32 PM
Rugby3's Avatar
Rugby3
I imagine that while running it without the front drive shaft I should also leave the wiring harness to the TC unhooked as well?
