Roadside repairs suck!
Old May 2, 2009 | 07:31 AM
J1MMY's Avatar
J1MMY
Currently have the truck on 3 wheels and axle stand. How the @*!# do you get the balljoints out of the I beams without removing the beams? Do I not have a big enough hammer? Arghhh!!!
Old May 2, 2009 | 09:16 AM
LCAM-01XA's Avatar
LCAM-01XA
DO you have ball joints, or kingpins? My '90 has ball joints, but my buddy's '86 has kingpins, I can swap both ball joints on one side in less than 3 hours, but kingpins are a whole different animal. And for the ball joint you'll need a ball joint press (looks like a huge C-clamp, but with many different adapters for both ends), not quite sure what kingpins take tho...
Old May 2, 2009 | 09:59 AM
hittman1422's Avatar
hittman1422
took me 2 days to get my ball joints out... after we got done that press was bowed to all get out!
Old May 5, 2009 | 04:24 AM
J1MMY's Avatar
J1MMY
Balljoints, and I'm conceding that I'm gonna have to get the beams off to sort it.
Old May 5, 2009 | 05:00 AM
88-150's Avatar
88-150
i used a mallet and a 1/2" brass rod to pound em out and the mallet to pound em back in. Their a pain in the rear unless ya wanna take the arms off and have em pressed off and on.
Old May 5, 2009 | 07:32 AM
IrishBusDriver's Avatar
IrishBusDriver
They make a "C"-type clamp that has adapters to press out the jouints and then you reverse the adapter to press them back in. It is not easy,but it is simpler than beating them out and in. You should be able to rent one at a good rental shop, Mike
Old May 5, 2009 | 10:58 AM
Redneck1465's Avatar
Redneck1465
If you use the clamp they are relatively easy to do in regards to trying to beat them out.
Old May 5, 2009 | 11:13 AM
J1MMY's Avatar
J1MMY
You guys have all the tools!
Old May 5, 2009 | 12:09 PM
86bigred's Avatar
86bigred
my ball joint tool is great for removing u joints as well.i figure every tool box should have one.they are not that expensive.
Old May 5, 2009 | 12:59 PM
Redneck1465
Once you need it it is definately worth buying your own...
Old May 5, 2009 | 03:01 PM
HappyGA's Avatar
HappyGA
you can also use AutoZones lone a tool program. You pay for the tool, and if you break it, no problem they have it warrantied. Once you are done, you give it back, and they give you the same amount you paid back.
Old May 5, 2009 | 04:47 PM
J1MMY's Avatar
J1MMY
Do they post to the UK? lol
Old May 5, 2009 | 06:16 PM
ctubutis's Avatar
ctubutis
How-to tutorials on ball joint replacement
I have three bookmarks set up in my browser aboyut this, I'm thinking of doing my ball
joints this summer.
The first one is text & pictures, the other two are videos:
Bronco Ball Joint Replacement - Trucks 4x4 @ Off-Road.com
How to Press Out a Truck's Lower Ball Joint | Expert Village Videos
How to Install a Truck's Lower Ball Joint | Expert Village Videos
-ct
Old May 5, 2009 | 06:59 PM
86bigred's Avatar
86bigred
that a great site even for the advanced do it your selfer,i bookmarked it for future reference.ive got the same style of remover he has.was the best 100 bucks i spent.like i said it's good for removing ball joints as well.alot quicker than the vice and socket method.
Old May 5, 2009 | 07:27 PM
MUSKY1011's Avatar
MUSKY1011
ball joint press at harbor freight, $39.99
