3.73 Axle Code
Old Sep 27, 2002 | 11:22 PM
pcman's Avatar
pcman
3.73 Axle Code
I need to know the axle code found in the door for a 1990 f-150 with a 3.73 ratio and limited slip. I have found some codes but do not know which is the correct one, here are the ones I have found:
B4 C4 D1 E1 all 3.73 limited slip but which one is for a f-150 with 31 spline axles and 8.8" ring and pinion.
Thanks.
Old Oct 2, 2002 | 01:00 PM
DoubleA's Avatar
DoubleA
3.73 Axle Code
all of the trucks have 31 spline axles.
Maybe do a search for axle codes, the difference is probably the weight ratings.
Old Oct 2, 2002 | 05:47 PM
TOUGHLover's Avatar
TOUGHLover
3.73 Axle Code
