Sponsored by: Real Truck
electrical problem
Old May 1, 2009 | 08:57 PM
mrpurdum's Avatar
mrpurdum
electrical problem
1/2 the time the window and wipers won't work for the first 30 sec after start up. You can hear a relay pop then they work normally.
Thanks Greg
Old May 1, 2009 | 09:44 PM
DAVE67FD's Avatar
DAVE67FD
Locate the associated relay that controls these functions. Remove the relay and physically inspect it and it's contacts. If it looks ok (no corroded or discolored contacts/cracked case etc..) then swap with another relay of the same size and type. If no change in function occurs then your only other alternatives would be to physically inspect/troubleshoot the affected circuit, take to a qualified repair facility or dealer. Listing the trucks details (year/mileage etc..) is always a good idea so others have better information to help or guide you in your problem.
Good luck
Old May 1, 2009 | 09:51 PM
mrpurdum's Avatar
mrpurdum
sorry 1999 f350 7.3 auto
Thanks I'll try the relay check
Old May 1, 2009 | 11:05 PM
DAVE67FD's Avatar
DAVE67FD
No appology needed.
Ohh and welcome to FTE
Dave
