Sponsored by: Kumho
Vaccum bleeding brakes
Old May 1, 2009 | 08:01 PM
bigcountry1009's Avatar
bigcountry1009
I tried to use a hand vaccum pump, the Mighty Vac I believe, to bleed the brakes on my '84 F-150. Came with a bunch of fittings and directions to bleed the brakes. Got fluid coming out of the bleeders, but I still had to do it the old fashioned way to get all the air out. Had to do it on my dad's dodge truck too. Any guys ever used this or something like it? had any luck?
Old May 2, 2009 | 06:56 AM
Lazy K's Avatar
Lazy K
A couple of years ago I bought one thinking it would make one man bleeding easy. Same as you I had to go back to two man conventional bleeding. I never figured out why it wouldn`t work.
I`ve often thought of making a pressure bleeder but never got around to it.
Old May 2, 2009 | 11:10 PM
pjwoolw's Avatar
pjwoolw
I've been using the Mighty Vac for a long time. Handy tool. But you do still have to finish bleeding the old fashioned way. I found you could use it with better results on smaller vehicles.
Old May 3, 2009 | 12:28 AM
flamebuster's Avatar
flamebuster
I tried the mighty vac. and the pump would not suck after it being used and put away. Even after cleaning. Need to be able to do one man bleeding so baught a pressurizer for the master cyl. and it works great..
Old May 6, 2009 | 09:10 PM
bigcountry1009
Well, ok, just wanted to make sure I wasn't doin it wrong.
Old May 13, 2009 | 12:09 PM
Aftrmidnite's Avatar
Aftrmidnite
You're pulling air from around the bleeder screw threads. I just loosen the jar lid at the end and let it gravity feed for a minute.
hurst1979olds
Apr 20, 2016 11:11 AM
RIKIL
Dec 29, 2014 03:41 PM
granny_rocket
Jan 21, 2014 02:54 PM
quakerj
Aug 25, 2013 11:51 PM
smuzz
Apr 6, 2010 06:53 AM
