2002 fuel pump change
Old May 1, 2009 | 08:26 AM
Tomm's Avatar
Tomm
Question 2002 fuel pump change
After reading through the tech thread I see that around '92 models it is easier to pull the bed off than to drop the gas tank to access the pump and/or float. Does anyone know if this is still the best way to go on my 2002 Ranger? I'm pretty sure my pump has puked out but if anyone has any suggestions as to what I should check out first before changing the pump, I'm all ears. I have checked the fuse and it is okay.
Old May 1, 2009 | 03:16 PM
Pablo-UA's Avatar
Pablo-UA
the best way is to remove bed. 6 bolts off (you can use impact wrench to do it faster)....
ask someone to help becouse bed is about 50 kg.
Old May 20, 2009 | 08:14 PM
Tomm's Avatar
Tomm
Thanks Pablo, it all went well. It was easier to remove the bed. I can't imagine trying to get the lines disconnected by dropping the tank, I'm glad I didn't waste the time and energy.
There are a few other tricks that I learned in the process so if anyone wants to know about it all just shoot me a message.
