Auto ID help
Old Oct 5, 2002 | 12:24 PM
greymule's Avatar
greymule
Post Auto ID help
I would like to know what automatic trans this is. It is mated to a carbarated 351M. The trans pan has 14 bolts with indents in the left front & rear. The pan is 9 inches (front to rear) by 11 inches (left to right). There are 6 positions on the shift lever. The trans has 3 sections (bell housing, center & tail shaft).
Old Oct 6, 2002 | 12:33 PM
IamHated's Avatar
IamHated
Auto ID help
lets see, being a carburated model, its what, no later than an 86' right? since i believe there was only 2 automatic trannys ford used then, i'd put my money on a C-4. 6 shifter positions(P,R,N,D,1,2) leaves it to be a 3 speed, and the fact that its in 3 sections(C-6 has bell houseing and center section in one peice) and 14 pan bolts instead of 17(or 19, don't rember) on C-6.
Old Oct 6, 2002 | 05:02 PM
greymule's Avatar
greymule
Post Auto ID help
An "old timer" I talked to last night said this is probably a fmx. He said they came with two different tail shafts, one made of cast & one made from alloy. Since mine is made of alloy he said it propably came from a "car" of the mid to late 70's vintage
Old Oct 7, 2002 | 07:03 PM
IamHated's Avatar
IamHated
Auto ID help
never heard of an "fmx"....ever. did ford make it?
Old Oct 8, 2002 | 01:40 PM
greymule's Avatar
greymule
Post Auto ID help
FMX=FORD-O-MATIC. Supposedly Ford introduced this trans after the C6 & b4 the AOD.
Old Oct 8, 2002 | 04:27 PM
dbarracuda's Avatar
dbarracuda
Auto ID help
