Water pump replacement
Old Apr 30, 2009 | 04:35 AM
ukexplorer's Avatar
ukexplorer
Just replaced the water pump on my 98 4.0 SOHC at 115 k miles. Here are some of my experiences. You definitely need the special tools for removing the viscous coupled fan. One of them holds the water pump pulley from rotating while the other is a 36 mm open ended wrench to undo the big nut at the back of the fan.
You can do this job without removing the radiator but it is much easier if you do as you have to scrape traces of the old gasket from the joint face on the block. Removing the radiator shoud be easy - I say "shoud be" because on mine two of the spring clips holding the hoses on the radiator were broken and it took a long time wrestling the hoses off. Replaced them with proper wom drive clips. Save your coolant solution for re-use.
The twelve bolts which secure the new water pump to the bock should be torqued to 8.5 to 12 Nm.
Goes back together much quicker than tearing down. When reassembling, position the worm drive on the bottom hose clip connection toward the left side of the truck otherwise you will not be able to replace the fan cowl. I had to re-do this. Re-filling takes time and patience to eliminate air locks. No leaks! Good luck.
