Sponsored by: Auxito
can P1451 cause rough idle?
Old Apr 29, 2009 | 10:17 PM
MikeD1980's Avatar
MikeD1980
truck is showing P1451 code. has stuttering kind of idle. are these related? Advanced Auto Parts (people who scanned it) said it was nothing and offered no help.
Old Apr 30, 2009 | 05:22 AM
chaser1602's Avatar
chaser1602
OBD Trouble Code: P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction
And I always make sure the gascap clicks when they are tightened and the o-ring is not cracked or broken.I always start there with evap codes.Bad gas caps most always cause evap codes
Old Apr 30, 2009 | 05:35 AM
projectSHO89's Avatar
projectSHO89
P1451 is not related to the gas cap. It will not cause idle issues.
It is an electrical fault for the vent solenoid circuit. Check for damaged/corroded wiring to the solenoid.
