Sponsored by: Real Truck
Catalytic converter help
Old Apr 29, 2009 | 05:16 PM
2001SuperDuty's Avatar
2001SuperDuty
Been under the truck billions of times now to find what the heck keeps sounding like a vibration or exhaust coming out a hole in the system. well didnt find any hole, all shields are tight and dont move, could my converter be broken? Is it really going to cost a couple hundred bucks for one?
Old Apr 29, 2009 | 05:22 PM
mwsF250's Avatar
mwsF250
It is not unheard of for the catalyst "honeycomb" to be broken, but it is rather rare - and is usually accompanied by big dents in the casing...
And yes, a new one will be SEVERAL hundred dollars to get one large enough for this engine. If you don't use it for heavy towing or hauling, you could use a smaller universal aftermarket, some of which are around $100.
I would definitely pull it and inspect it before dropping the cash!
Old Apr 29, 2009 | 07:19 PM
enduro4231's Avatar
enduro4231
If it was me and I had to replace my cat anyway, I would go with a high flow SS unit.
Old Apr 29, 2009 | 07:35 PM
Bear River's Avatar
Bear River
Former ******
We have units for a little over $100, and they can be used for towing.
What is a high flow SS unit?
Old Apr 29, 2009 | 07:45 PM
enduro4231's Avatar
enduro4231
High flow stainless steel catalytic converter.
http://www.pypesexhaust.com/images/cvm10k.jpg
Old Apr 29, 2009 | 07:53 PM
Bear River's Avatar
Bear River
Former ******
Those are not high flow cats for any application over 3.8L. You notice that have a maximum displacement rating of only 5.0L, and a max GVW rating of only 4,000 lbs.
To get more flow through a larger vehicle you need larger cats.
eBay Motors: OBDII Universal Catalytic Converter LT Truck Series (item 160330653574 end time May-24-09 09:37:13 PDT)
We also offer these same units in a true high flow 300 cpi ceramic for ever better results in our Tru-Performance line, as well as a Heavy Duty version of this same cat that can more easily handle the heavy towing. (PM for details)
Old Apr 29, 2009 | 08:02 PM
enduro4231's Avatar
enduro4231
This I did not realize. The link, however, served merely as an example of what I was speaking of, not of the proper cats of a Super Duty. Do you offer stainless steel cats?
Old Apr 29, 2009 | 08:23 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Why not remove the insides and let it be.....
Old Apr 29, 2009 | 08:25 PM
FX4 5.4's Avatar
FX4 5.4
i am pretty sure it is illegal to gut the cats
Old Apr 29, 2009 | 08:37 PM
Furian's Avatar
Furian
You Keep What You Kill
That particular cat is made of 409 stainless steel... I like SS too!
100% 409 Stainless Steel Casing
Durable casing will not warp or flex
High Flow Design
Perfect for maximum airflow and sound
Malleable Materials
Ends can be expanded without cracking or splitting
5 year/50,000 Mile Warranty
Guaranteed to function correctly on properly tuned vehicles
No More Check Engine Lights
Advanced catalyst technology guarantees higher efficiency
Made in the USA
Old Apr 29, 2009 | 09:09 PM
enduro4231's Avatar
enduro4231
Are you speaking of the Bear River cat or the Pypes one I posted?
Old Apr 29, 2009 | 09:14 PM
Furian's Avatar
Furian
Bear River's cat...
Old Apr 29, 2009 | 09:21 PM
2001SuperDuty
Bear River- So your sayin you got a brand new converter for a 2001 250 V10 for just over $100???? if you do ill take one
Old Apr 30, 2009 | 04:31 PM
Bear River's Avatar
Bear River
Former ******
Ok, here is the link. We would normally sell these on our website, but it is under construction.
eBay Motors: OBDII Universal Catalytic Converter Heavy Duty Series (item 170327237255 end time May-30-09 14:24:54 PDT)
Nseal1996
15
Jul 20, 2012 10:42 PM
Stephen67
Jun 9, 2010 06:34 PM
scottddove
Mar 15, 2006 11:44 AM
Duksrule
Feb 23, 2005 07:01 AM
