speedometer again
Old Apr 29, 2009 | 04:46 PM
Jesse Zimmerman's Avatar
Jesse Zimmerman
speedometer again
alright i got the new vss on the diferential and the speedo is still dead Im thinking that its a loose wire under the dash somewhere. Any one know what wire it would be, were it is, what looks like, anything. Its a 1993 f150 xlt. thanks for any help.
Old Apr 29, 2009 | 06:08 PM
jr32560's Avatar
jr32560
you might try to do a search on this subject-I have seen a few posts on here about the speedo it self going out
Old Apr 30, 2009 | 02:59 PM
subford's Avatar
subford
The VSS wires run from the rear end sensor to the dash area and the ABS plugs in to them in parallel. The PSOM also plugs into the VSS wiring.
You have checked the fuses, if not check them first.
Unplug you ABS module and see if the speedometer starts working again.
Here is a diagram of the 1992 system, the 93 is the same:
http://i54.photobucket.com/albums/g9...M/1992FVSS.jpg
