looking for 302 mounts?
Old Apr 28, 2009 | 09:22 PM
bronkntrukholik's Avatar
bronkntrukholik
I have a '78 f150 4x2 stepside that had a 300 6cyl 4 speed in it, I am changing to a 302 and I need the left and right brackets that bolt to the frame and that the motor mounts set down into. If anyone would happen to have a spare set laying around any help would be appreciated.
Old Apr 28, 2009 | 11:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1969/79 F100's & 1975/79 F150's w/302 engines, use the same mount brackets (aka towers, supports, perches) as used on 1977/79 F100/350 2WD's with 351M/400's.
These brackets are obsolete, no longer available from Ford.
Old Apr 29, 2009 | 08:45 AM
73FOMO's Avatar
73FOMO
I can tell you what they look like....if you can peruse the salvage yards. The mounts sweep towards the rear of the vehicle....if that helps in identifying.
