zf transmission
Old Oct 12, 2002 | 08:54 PM
mark41's Avatar
mark41
zf transmission
i have a zf 4speed od tranny for a 2 wheel drive truck i would like to put this into my 92 f150 with 300cid motor ? if i find a rear housing can i convert this tranny or is there more detail ie changing the output shaft or other ps my truck currently has the m5od any help would be appreciated.... thanks mark
Old Oct 14, 2002 | 11:15 AM
DannyP's Avatar
DannyP
zf transmission
If you are talking about using a 2wd ZF in a 4wd application, then I believe you will have to change the output shaft.
DannyP
Old Oct 14, 2002 | 01:40 PM
Hershey's Avatar
Hershey
zf transmission
