Rear Diff/driveshaft seal....Need help with install
Old Apr 28, 2009 | 01:34 PM
dferg476's Avatar
dferg476
Fellas!!
Hey my vent was blocked on the rear axle and caused the seal between the rear diff and the driveshaft to blow out. I need to replace it and was wondering if anyone has done the job and how hard it is.
It's a 9 inch rear. I assume I take off the driveshaft, then after there I am kind of stumped. Do I unbolt the five bolts on the part sticking out of the diff and pull that out and replace or do I have to undo the bolt that goes into the diff behind the driveshaft?
Thanks!!
Old Apr 28, 2009 | 04:10 PM
uncle.stosh's Avatar
uncle.stosh
It's called a pinion seal.
Yes, you have to take the large nut off to get the yoke off.
An impact gun is the best way to get it off. I'm not sure about 9" rears, but you may have to replace the crush sleeve as well if you remove the nut. That large nut when torqued determines the ring and pinion mesh and it's very important to get it right.
Old Apr 28, 2009 | 08:37 PM
bashby's Avatar
bashby
If you mark it before the nut to the shaft and put it back in the same spot you should be ok with your old crush sleeve
Old Apr 28, 2009 | 09:28 PM
Slyreaper's Avatar
Slyreaper
Here you go. I need to do the same thing some time when I get a few days off from Auto Zone.
AutoZone.com | Membership Benefits
Old Apr 28, 2009 | 10:53 PM
dferg476's Avatar
dferg476
Thanks guys, I think I need to get an impact gun anyhow, so I'll check criagslist and see if I can pick one up. Thanks again fellas!
Headviking
Jul 11, 2021 05:54 PM
1975FordF250
Apr 4, 2015 11:34 AM
ol' gray
1997 - 2003 F150
18
Jan 29, 2013 10:09 PM
budwich
Escape & Escape Hybrid
Apr 25, 2011 10:17 AM
jmgekeler
May 25, 2010 10:27 PM
