8.8 Rear end's strength
Old Oct 15, 2002 | 11:39 AM
MustangGT221's Avatar
MustangGT221
I've been told that the 8.8 can handle 500hp with slight modifications. I was wondering how strong this axle is (hp wise)? Is there a large difference between the 28 spline mustang/thunderbird/ranger axles and the 31 spline truck axles? What does the extra splines help more with, accepting engine torque or the extra towing/load of a truck?
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Oct 16, 2002 | 12:57 AM
cac91's Avatar
cac91
Old Oct 16, 2002 | 03:32 PM
Squiggy's Avatar
Squiggy
I dont think its a case of the splines and the gears themsleves I think its the bearings. the bearings are the only defense in keeping moving shafts from hitting the casing. if you slam 500 hp against a bearing thats weak it will fail causing it to move and everything else goes with it. If you upgrade the bearing say to a stronger one I think you can run anything. But the question of the splines is probably having to do with size of the entire shaft diameter. If you got 28 teeth, the thickness of each spline is bigger than one with 32 teeth. I would choose the one with 28 because of strenth issues
Old Oct 16, 2002 | 03:58 PM
StrangeRanger's Avatar
StrangeRanger
IIRC the 31 spline axles are quite a bit larger and therefore stronger.
Old Oct 16, 2002 | 08:46 PM
MustangGT221
Would a 31 spline respectively hold 400-500hp stock?
