Offroad & 4x4
efi to carb
Old Apr 27, 2009 | 11:47 PM
rebelpride1653's Avatar
rebelpride1653
efi to carb
i have a 92 f150 4x4 5.0L efi with a m5r2 manual trans. i am wondering what it entails to convert it to carb
in the process of turning the 302 into a 347 stroker and lifting it 10 more in
thanks any input is helpful
Old Apr 28, 2009 | 06:42 AM
fishmanndotcom's Avatar
fishmanndotcom
carb'd intake and a carb. thats pretty much it. i have never done this but i think you can just plug the injector ports and run that intake, just get a carb to sit atop!
someone correct me if i am wrong
-cutts-
Old Apr 28, 2009 | 12:38 PM
big bad 79 bronco's Avatar
big bad 79 bronco
hard to say u will have to keep most electronics with ur stock ignition system or convert to a msd box with a vacume advance distributor
Old Apr 28, 2009 | 05:36 PM
1966Tbird's Avatar
1966Tbird
here is the stuff you need https://www.ford-trucks.com/forums/8...carb-swap.html
and here is another thread on it https://www.ford-trucks.com/forums/82...carb-swap.html
Old Apr 28, 2009 | 05:39 PM
1966Tbird's Avatar
1966Tbird
i run a mechanical advance HEI dissy but i would not run a HEI on a smallblock again they are way too big i had to use an offset aircleaner to do it, you need a bypass fuel pressure regulator and a 3/8ths return line and a bunch of -6an line (use this please 2 of my friends burned to death when a rubber fuel line on their mustang ripped off the carb and sprayed the dissy with -an lines this won't happen)
and i did not keep any of the stock fuel injection sensors just kept the computer because i don't know what else it controls
and you have to put a fuel pump switch in your truck
Old Apr 29, 2009 | 01:18 PM
hav24wheel's Avatar
hav24wheel
Originally Posted by rebelpride1653
i have a 92 f150 4x4 5.0L.......
10 inches of lift + F150 + big enough tires to fit under it + 347 = mall crawler, or Broken.
Old Apr 29, 2009 | 01:24 PM
MisterCMK's Avatar
MisterCMK
Why convert to carb rather than sticking with EFI?
Old Apr 29, 2009 | 01:29 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
can i have your old efi stuff? computer harnesses and everything?
Old Apr 29, 2009 | 03:04 PM
1966Tbird's Avatar
1966Tbird
in my experiance carbs are better in mud because there are less wires to get wet and have problems, a carb is a lot simplier and easier to tune, no sensors to go bad, i got better gas mileage after i switched to my carb, you can control your timing mechanically, looks a LOT cooler that efi, a carb doesn't care what duration your cam is (that's why i did mine so i could run a LUMPY cam)
and get a ZF tranny instead of the stock one you have the zf will handle the power of a 347, or you could get a tko 600 with a divorced np205 transfercase
and your ttb isn't going to hold up with anything more than 35s and you'll want a dana 60 swap as well for 10in of lift
Old Apr 30, 2009 | 04:20 PM
rebelpride1653
thanks i'm gonna do the 10" at the withe the straight axle conversion with dana 60's front and rear
Old May 2, 2009 | 09:42 PM
KubotaOrange76
carbs are a pain in the rear off road...nothing more annoying than being starved for gas because you are on an incline
keep the efi or put a propane carb on it
Old May 3, 2009 | 08:55 AM
1966Tbird's Avatar
1966Tbird
i have jet extentions in my carb and the breather holes linked together with a peice of hose with holes in it i have NEVER had a problem with fuel starvation after i did these mods
Old May 3, 2009 | 11:15 AM
TheTinian's Avatar
TheTinian
I agree it does suck being starved for gas.
But it also does suck if you go a little deeper than you thought and fry all you electronics because your hood went under for a second or two.
Old May 3, 2009 | 11:55 AM
hartski's Avatar
hartski
As always, it all comes down to application.
Hartski
Old May 3, 2009 | 02:43 PM
trugertha's Avatar
trugertha
its carb all the way.. they got carbs you can go on crazy angles with. no computers they suck!
