Water injection help
Old Apr 27, 2009 | 07:37 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
I got this kit http://www.coolingmist.com/detailmai...50psidieselkit
it says pump is adjustable from 100-250psi. Can i adjust that myself? If so how?
also i'm not going to use the nozzles that came with it. Thinking bout just using 1 big one. Should i just get a water nozzle, since that will be the only thing i run through the system. What size should i go with? I don't need a lot of water, just enough to keep <acronym title="Exhaust Gas Temperatures">egts</acronym> cool when racing or pulling. Coolingmist Water Injection, alcohol injection and Methanol Injection systems
Old Apr 27, 2009 | 08:02 PM
CSIPSD's Avatar
CSIPSD
also i'm not going to use the nozzles that came with it. Thinking bout just using 1 big one. Should i just get a water nozzle, since that will be the only thing i run through the system. What size should i go with? I don't need a lot of water, just enough to keep <ACRONYM title="Exhaust Gas Temperatures">egts</ACRONYM> cool when racing or pulling. Coolingmist Water Injection, alcohol injection and Methanol Injection systems
You can turn the pump up yourself. Its set at the factory to about 200psi, but you can turn it up. There is a hex or allen bolt on the top of the pump, have to turn that in more.
Use the injectors that came with the kit, they are some of the best itomizing injectors avalable.
Old Apr 27, 2009 | 08:57 PM
Farmboypowerstroke
would you happen to know what size the nozzle is that came with the kit, the bigger one. cause i have to buy a new one, i kind of broke it
Old Apr 27, 2009 | 09:00 PM
CSIPSD's Avatar
CSIPSD
Not sure, you can e-mail them and find out, I think they send a 375ml and a 500ml with most of there kits...
Old Apr 27, 2009 | 11:15 PM
surveyguy's Avatar
surveyguy
it says if you're running over 435 HP then you use the bigger one.
Old Apr 28, 2009 | 06:26 AM
Farmboypowerstroke
He said the large nozzle flows 16GPH at 250psi. that sounds right?
