Odd washers...Something missing?
Old Apr 27, 2009 | 03:51 PM
BillyBob69's Avatar
BillyBob69
I have the ESOF on my 99 PSD and yesterday, I finished up the ball joints by completing the right side. I was thinking about it today, I and I recall that the large flat washer with the 4 grooves against the hub assembly was NOT there. Just a large flat washer. It is there on the drivers side. Is this right? I have always blamed my ESOF not working right due to old and cracked vaccuum lines so I have just locked the hubs in manually. But now I am questioning that. or maybe assigning some of the blame to the wrong washer being in there. I took them out and kept them on the hub in the same order they came out so that they would go in the same way.
Old Apr 28, 2009 | 09:14 AM
superduty4x4's Avatar
superduty4x4
You need that grooved washer in there, the grooves are what allows the vacuum to get to the hub IIRC.
Old Apr 28, 2009 | 09:15 AM
BillyBob69's Avatar
BillyBob69
Guess its time to hit the parts store then huh?
Old Apr 28, 2009 | 09:22 AM
superduty4x4
I'd say so. I'm not sure if its a Ford only part or not.
Old Apr 28, 2009 | 09:24 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You may already know this, but I will throw it out anyway.
You can look on here and see how the washers go. click here
Old Apr 28, 2009 | 10:05 AM
BillyBob69's Avatar
BillyBob69
yea I have the order down...It just hit me later that I didn't notice the grooved washer was not there. Now just to locate the PO and smack him for it.
Old Apr 28, 2009 | 10:09 AM
miller_feed
At least you figured that out. You may have your ESOF back.
Old Apr 28, 2009 | 10:11 AM
BillyBob69's Avatar
BillyBob69
I hope so. I replaced the steering knickle seal and axel seal while I had it apart and the yellow O-ring too. In the process tho I bent one of the vaccuum nipples on the hub assym. so I need to replace those too.
Bryan Hagan
Oct 23, 2016 07:29 PM
wrdabney
Oct 7, 2016 03:29 PM
ExPACamper
21
Sep 24, 2016 09:25 PM
Billyclub
15
Jul 10, 2016 07:33 PM
olderf150
Feb 26, 2016 10:04 AM
