side mirrors stuck...
Old Apr 27, 2009 | 03:42 PM
fkaster01's Avatar
fkaster01
Question side mirrors stuck...
I have had this problem for a while now but am just now looking to fix it. I can't fold the side mirrors in on my 95 f150 supercab and don't want to break them trying to force them. I don't really want to replace them either as i'm a little short on cash lately. I tried to take the bottom bolt out and lift them up a little but that didn't work. tried using blaster and lithium grease to lube them up a little and that didn't work either. I can't get the truck in my back yard if I can't fold in the mirrors and would really like to get it back there before I take the front end apart. Any suggestions would be appreciated, thanks.
Old Apr 27, 2009 | 03:50 PM
6CylBill's Avatar
6CylBill
Are you sure they're stuck? Mine feels the same way. I have to apply preasure until I think something is about to break.. THEN my mirrors fold in.
Old Apr 27, 2009 | 03:56 PM
Jermafenser's Avatar
Jermafenser
They have been rusted on.
If you don't keep the mirrors lubed and fold it once in a while, they will rust on and get stuck.
Old Apr 27, 2009 | 04:10 PM
6CylBill's Avatar
6CylBill
Is there any kind of chemical or lube he can use to get the mirrors unstuck? What about Penitrating oil like PB?
Edit: What type of oil should I use to keep my mirrors lubed?
Old Apr 27, 2009 | 06:06 PM
Jermafenser
Yes. PB Blaster, Liquid Wrench, Kroil, etc. and a wire brush to eat away the rust.
Any weather-resistant grease will work; the same kind you use to lube the doors with white grease will be fine. Do this annually or each season, whichever you prefer.
I'd take the mirror apart and see how bad it is, and reassemble with grease to keep things moving. Some times they are just rusted beyond repair.
See this thread on an identical problem; the OP gives an in-depth explanation. https://www.ford-trucks.com/forums/8...or-repair.html
Old Apr 27, 2009 | 09:38 PM
fkaster01's Avatar
fkaster01
they are plastic so i'm not sure rust is the issue. any metal parts would be internal
