Sponsored by: Auxito
97 f150 u-joints
Old Apr 27, 2009 | 03:02 PM
pfd843's Avatar
pfd843
97 f150 u-joints
hey all. long time lurker, 2 or 3 time poster. quick question, how hard is to change the u-joints on a 97 f150, 4.6 liter extended cab 4x4? i do my own maint. and basic repairs and was curious if this is something that a normal guy can do or do i need a shop with $20000. worth of tools. the u-joints are not broke, just making the "dry metal" grinding noise. had it in the shop for a radiator flush and they noticed it was u-joints. i thought it might have been rear brakes. thanks for the help.
Old Apr 27, 2009 | 03:42 PM
phil6608's Avatar
phil6608
It's not very difficult. Normal tools(sockets) and maybe a snap-ring tool.
Just unbolt the 2 little U bolts in the back end and pull the hole driveshaft out of the tranny. Now you can take it out from under the truck,put it on a workbench or your driveway and work on it.
Only problem I ever had was the little cup coming off the U joint itself,so ya need to be careful to keep them on there.
Old Apr 27, 2009 | 05:03 PM
fast68's Avatar
fast68
if you put the new u joints in the freezer it will help knock them in
use alot of grease to slide the new ones in, it helps sometimes
i use an old axle pinion shaft and a BFH
make sure grease zerk is pointed the right way too, it sometimes matters or it will get broken off
have fun
Old Apr 27, 2009 | 08:26 PM
pfd843's Avatar
pfd843
thanks for the help. gonna give it a try saturday. want to get these done before boating season gets going.
Old Apr 28, 2009 | 01:43 PM
KingRanchMan02's Avatar
KingRanchMan02
It may not make a difference but, I would mark the yoke and the flange to the drive shaft before dis-assembly and put them back together the same way that they came apart. Good luck!
Dean06919
Jul 26, 2016 09:28 PM
1984F2506.9
Dec 4, 2014 11:32 PM
93f250tn
Aug 8, 2014 02:58 PM
lannondiesel
1997 - 2003 F150
Nov 27, 2008 09:56 PM
guitars2
Nov 5, 2001 09:29 PM
