Power steer and such...
Old Apr 26, 2009 | 04:46 PM
Mydiesel250's Avatar
Mydiesel250
Alright so Im sure I could find the answer if I did enough searching but Im exhausted from changing wheels tires, so bear with me. Ok so I noticed it being hard to turn the wheel if im sitting still, in park , drive, foot on brake and off you name it sometimes it just goes out. Some times it goes out around 10 to 15 mpg randomly like while steering around Homedepot parking lot looking like an idiot fighting the wheel. AAAnd now that put 35" tires on I feel a very slight shake in the wheel. I belive this needs a damper upgrade? Im up to my shoulders in brake dust and dirt, any help would be greatly appriciated. Thanks
Old May 3, 2009 | 10:51 PM
EXv10's Avatar
EXv10
being a https://www.ford-trucks.com/forums/8...ml#post7407611 Look at this post. And maybe a slipping belt? Bad PS pump. Check your PS oil level.
Old May 4, 2009 | 09:43 AM
cbradford's Avatar
cbradford
A damper upgraded is not going to help turning the wheel a low speed or stopped so as EXv10 mentioned above is a good place to start.
