Tranny Temp Sender?
Old Apr 26, 2009 | 07:07 AM
TchTchr's Avatar
TchTchr
Tranny Temp Sender?
Hey all,
My temp sender is leaking. Isspro only sells the sending unit with a new guage. I don't need a new guage. Any alternative sending units out there or is this a calibrated set (like according to isspro)?
Thanks,
Brad
Old Apr 26, 2009 | 07:28 AM
mattpowerstroker's Avatar
mattpowerstroker
where is it leaking at can u put some teflon tape on it..
Old Apr 26, 2009 | 07:33 AM
DieselCamper01's Avatar
DieselCamper01
If it is a single wire sensor you cannot use teflon tape because it grounds through the contact between the sender and the pan. Not sure on how universal those senders are.
Old Apr 26, 2009 | 08:05 AM
TchTchr's Avatar
TchTchr
Sorry for not being clear. It is a two wire design. The sensor probably got dropped (by me or previous owner) at some point. The brass around the sensor is completely broken off now. The leaking is coming out of the area surrounding the wires.
