Smog control
Old Apr 25, 2009 | 10:35 PM
Etype R's Avatar
Etype R
Smog control
Well I had to replace one of my valve cover gaskets today, and had to remove the intake plenum in order to get to it. Now I am putting it all back together, and these smog lines are really frustrating. Also the EGR tube behind the intake blew out, the rubber line looked like some mice chewed on it. So basicly I've been running with half the EGR system unhooked as it is.
What all can I remove with the smog stuff? Is it safe to remove anything and everything that has a line connecting to the smog pump? I've never removed smog stuff before, and not having much luck searching for a solid topic on it. I was able to find that I need a 91.5" serp to bypass the smog pump
