NP205 and NP203 Transfercase
Old Oct 27, 2002 | 07:29 PM
fordrocks's Avatar
fordrocks
What lube do you use in these cases..? Or do they use the same lube?
Old Oct 27, 2002 | 09:39 PM
Schwee's Avatar
Schwee
yo.....
there are many answeres,,, ford in 1 of thier shop manuals says to run 50 wght.... as gear oil is to thick and it wont oil the chain,,,,
haynes says 140 wght.....
a guy i know runs mobil-1 synthetic,,, 90 wght..... and has for 250,000 plus miles,,,,,which is the way iam gonna go....
good luk
Old Oct 27, 2002 | 10:00 PM
fordrocks's Avatar
fordrocks
hmmm.. see the np205 is gear driven.. so i guess i could run the thicker 90wt in it.. ? I just put a new np205 in my 77' 4x4 and i dont know what kinda lube to use.
Old Oct 28, 2002 | 09:17 PM
kspilkinton's Avatar
kspilkinton
If it's a brand spankin' new 205 you should be able to get a manufacturers recommendation. It'll depend on the seal and internal composition as to which oil weight to use. Info I have says 90W gear lube, but I'm sure you could use a multi-vis like 75W-90 or something around that neighborhood.
-Kerry
Old Oct 28, 2002 | 09:39 PM
mtcwby01's Avatar
mtcwby01
hornet41
Feb 18, 2007 01:09 PM
FERacing66
13
Oct 18, 2004 08:34 PM
SGTFA
Jan 20, 2003 04:43 PM
lanero
Oil & Lubrication
Sep 20, 2002 10:34 PM
69 F100 4x4
Oil & Lubrication
Mar 21, 2002 08:46 PM
