Tranny model
Old Apr 25, 2009 | 08:15 PM
truckdriver_mn1984's Avatar
truckdriver_mn1984
Tranny model
again the truck isn't here and im looking at some parts and need the model.
<!-- / icon and title --> <!-- message --> 87, F150 5.0 4x4. Its an auto.
The trans indicator reads P R N OD 2 1
Is this considered a 3 speed, or a 4 speed because of the overdrive?
Old Apr 25, 2009 | 08:23 PM
truckdriver_mn1984
I do know that the door ID tag says T for the trans, but i cant find anything when searching.
Old Apr 25, 2009 | 08:24 PM
85e150's Avatar
85e150
Probably the AOD. Too early for 4R70W and E4OD, AODE not found in trucks IIRC. A bit weak, but fixable. See ID info here:
https://www.ford-trucks.com/article/...ers_Guide.html
As to 3 or 4: If the speeds are integrated into the trans, and controlled via one shifter (even with the silly buttons), it's a 4 or 5 or x speed trans.
Manual or auto does not matter.
If it has an OD unit on the tail, controlled by it's own switch or other mechanism, it's 3+ OD, or like Corvettes, Volvos etc, 4+ OD. (Even though the Volvo button was on the stick, the OD was on the tail separate from the trans. Not sure about the 'Vette.)
