Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
77 tranny
Old Apr 25, 2009 | 04:12 PM
etnies13's Avatar
etnies13
77 tranny
so i need to drop my pan and chenge the fluid in my tranny and im told that it might not take regular tranny fluid. So what kind of tranny fluid will it take? I dont know if it is a c4 or a c6 but it is bolted to a 400 v8.
Old Apr 25, 2009 | 08:49 PM
Fomoko1's Avatar
Fomoko1
As far as I know if it`s a 400 engine it should be a C6.
I can`t help with the recommended transmission fluid, if no one else chimes in soon check in the Clutch,Transmission, Differential, Axle and Transfer Case forum: https://www.ford-trucks.com/forums/forum69/
Old Apr 25, 2009 | 09:36 PM
77SilverStreak's Avatar
77SilverStreak
If its never been rebuilt recently, then you have to put Type "F" transmission fluid in. DO NOT use Dextron oil or it will shift and operate like crap. If it has been rebuilt in the last few years then the seals will be updated to accept the Dextron oil. Stay on the safe side and use Type "F" fluid. Also if you are dropping the pan to change oil, open the torque converter access cover and turn the engine over till you see the drain plug on the convertor and drain it too.
Old Apr 26, 2009 | 07:25 AM
preppypyro's Avatar
preppypyro
Learn something new every day, I woulda figured that dextronIII woulda been the stuff to use!
I havent seen much type F, can you get it in a synthetic at all too, or is that not reccomended?
Old Apr 26, 2009 | 10:44 AM
77SilverStreak
That's a good question Sheldon, I'm not sure if its avaliable in a synthetic oil. There is less and less places stocking the oil now, but I think Canadian Tire still carries it in stock. If your doing a full oil change including torque converter, it will hold around 10-12 litres I think.
Old Apr 27, 2009 | 09:25 AM
preppypyro's Avatar
preppypyro
Im pretty sure Ive seen the dino stuff at canadian tire, and I think at walmart too< never in a syn though, thats why I was curious.
Old Apr 28, 2009 | 06:37 PM
etnies13's Avatar
etnies13
thanks guys
Old Apr 28, 2009 | 10:30 PM
preppypyro's Avatar
preppypyro
Hey Bryce, if you do happen to find synthetic type f, let us know!
Old Apr 29, 2009 | 12:37 AM
etnies13's Avatar
etnies13
went to partsource for the type f tranny fluid, didnt see any synthetic tho
Old Apr 29, 2009 | 01:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
LOL...I just typed the following a few minutes ago...and have typed it prolly 100 times here on FTE.
VERBATUM from the 1973/79 Ford Light Truck and 1973/79 Ford Passenger Car Parts Catalogs:
XT-2QDX .. Automatic Transmission Fluid "MERCON"
For use in 1977/ C4 & C6 automatic transmissions.
Bottom Line:
C4's used Type F from 1964 thru 1976. 1977 and later used MERCON.
C6's used Type F from 1966 thru 1976. 1977 and later used MERCON.
Old Apr 29, 2009 | 07:20 AM
preppypyro's Avatar
preppypyro
Bill, ever seen synthetic type F?
Old Apr 29, 2009 | 01:58 PM
NumberDummy
Nope....if it's available, it's after my time.
Old Apr 30, 2009 | 08:21 AM
preppypyro's Avatar
preppypyro
God to know Bill, thanks
Old May 1, 2009 | 09:58 PM
77SilverStreak
Wow Bill, i didn't realize that! I thought Type F was used till 1979. Now I know!
Old May 2, 2009 | 08:22 AM
preppypyro's Avatar
preppypyro
Its crazy the amount of knowledge about fords, that Bill has!
