First I just installed a new 4 bbl carb w intake edlebrock and I cant seem to get the timing right book and sticker say 8 degree off top dead center and it still has backfiring boggy and exesive engine noise but cant find any other problems also cant accuretly check rpm tack doesent work(need help on that too) but have timing light anything to help please
1980 bronco 302 4bbl carb dual exaust manual 4 sp no overdrive
thaks
8 degrees "off" TDC? Which direction? I would assume BTDC (Before Top Dead Center) but it makes a major difference. Timing light will be more accurate than "by ear". No SPOUT connector on an '80 and I don't think the distributor used a vacuum advance anymore by 1980 either. But on the off chance that you do still have a vacuum advance on the distributor you will need to pull the vacuum line and plug the line so there is no vacuum leak while you set the timing. Vacuum advance is pretty obvious it will be a vacuum line directly into a dash pot on the side of the distributor.
