max weight
Old Apr 25, 2009 | 12:30 AM
Fraser19's Avatar
Fraser19
max weight
hey i have a 2008 B-4000 what is the max weight i can put in the box ?
Old Apr 25, 2009 | 01:38 PM
Fraser19's Avatar
Fraser19
it would also be helpful if you could post the max weight you have put in your ranger/b-series
Old Apr 25, 2009 | 03:42 PM
stu37d's Avatar
stu37d
Government Teat-sucker
I haven't had a problem hauling several hundred pounds. Probably less than 1,000, though. I'm sure I wouldn't have a problem hauling half a ton, though I wouldn't do it on a daily basis.
Old Apr 25, 2009 | 09:28 PM
Old93junk's Avatar
Old93junk
My Ranger is a lot older (84) than yours, I have put 1,500lbs of dirt in the bed with no problems.
Old Apr 25, 2009 | 10:28 PM
racsan's Avatar
racsan
as far as "safely" subtract your G.V.W.R. (posted on drivers side door jamb) from your truck's weight (go to a grain elevator, even during the off-season or after hours, most leave the scale on and the readout is visable from outside) my '93 has a G.V.W.R of 5040 and weighs in at 4,300. "technically" 740 pounds is what i could safely haul in the box, (minus any passengers or driver) ive had close to 1,000 in the bed before, but it does increase the ability to safely stop. i do have 1,200 pound-rated helper coils on my truck, they dont contact the frame until i have about 300# in the bed.
Old Apr 25, 2009 | 10:49 PM
reddog99's Avatar
reddog99
I've hauled 1700 lbs. of paving stones in my Ranger (see sig.) several times. That's probably over it's rating. It would start to wallow if I pushed it, but the bump stops weren't hitting and it handled OK at moderate freeway speeds. Seemed to brake OK, too.
