Headlight bulb replacement - '50 Effie
Old Apr 24, 2009 | 05:35 PM
Woodsman_30350's Avatar
Woodsman_30350
Will standard 7" sealed beam headlight bulbs work as a suitable replacement for my F-1? It has an 12 volt EZ Wiring harness. I assume they would fit the stock headlight buckets.
Old Apr 24, 2009 | 09:26 PM
mytbtruck's Avatar
mytbtruck
I got headlight sealed beams from Walmart for my 48 and they fit perfect. I also used the EZ wiring harness and used the new wires for the headlight buckets.
Old Apr 24, 2009 | 09:45 PM
Julies Cool F1's Avatar
Julies Cool F1
They should. Take the old one with you to make sure the prongs are the same!
