e40d gasket leak
Old Nov 2, 2002 | 07:55 PM
the law's Avatar
the law
e40d gasket leak
Old Nov 3, 2002 | 02:04 PM
rcooper917's Avatar
rcooper917
e40d gasket leak
i have replaced the tranny pan gasket 3 times, and it still leaks, the pan seems to be fine,didnt look warped, i have tryed the cork gaskets, and then the next time i used only black silicone,about a half inch bead,let it set. it seems that they work fine for about a day or two, and then they start to leak again, and i mean bad, i checked the vent tube, tryed to blow compressed air seem fine, is there something else that could be building pressure in the pan, may be a plugged cooler line,are some thing, im a farelly good manchanic. byt this pissess me of. thanks for any help
