H22 Axle code
Old Nov 3, 2002 | 01:35 PM
Fordman7780's Avatar
Fordman7780
H22 Axle code
On a 1980 ford f150 4x4 the axle code is a H22 does anyone what gear ratio that is. There is no tag on the rear cover and the axle is broke so I can't spin the tire to see how many times the driveshaft spins
Old Nov 3, 2002 | 03:43 PM
kspilkinton's Avatar
kspilkinton
H22 Axle code
[updated:LAST EDITED ON 03-Nov-02 AT 04:45 PM (EST)]I can't find a three digit axle code in any of my literature. It could be a mistype on the door jamb. I can find a 1980 code H2 as a 3.50 Ford 9". I show code 22 only in an 8.8" rear '83 and newer and a 4.10 ratio. You should have the 9", so most likely you'll have the 3.50 rear.
Another possiblity is to lock and rotate the front. This will give you a ball park number since the rear has to be pretty close to the same ratio.
-Kerry
Old Nov 3, 2002 | 06:01 PM
gadzooks's Avatar
gadzooks
H22 Axle code
WickdL
Oct 1, 2015 10:26 PM
jimistephen
Apr 3, 2015 09:06 AM
Ranger1980
18
Dec 28, 2014 04:10 PM
bcboy4ca
Mar 26, 2005 03:09 PM
