I just installed a 95/90 2014 55 psi fass unit because the stock pumps pressure was fading. The fass unit will only give me 22 psi and the secondary filter housing drains back to the tank.I triple checked the lines and all is correct so I am at a loss.My only thought is the stock pick up is plugged but that doesn't explain the drain back of fuel through the supply port in the secondary filter housing. Anyone know is there is a check valve in the stock pickup tube? Any ideas?
So....After putting a ball valve on the fass return line I get fuel pressure, but I have to manually adjust it and also shut it after each shut down. The shop I bought it from Peak Diesel (highly recommend them) was stumped and put me in contact with Dan from fass,who is also stumped. They are sending me out a new ball and spring to see how that works.So much for a easy up grade.
