05, F350 6.0 4x4 crew Larit . stop at light, eng quit,never started again. 1/4 tank on gas guage, computer on dash said i think 60 miles to empty. I did noticed the spot where it stopped had about 2 quart of oil on the ground, I towed it home added 2.3 quarts of oil and 5gal of diesel cycle the key three times with the brass plug on the side of the open then closed it, then opened the filter bowl let some air out ,then the screw several times still no luck. did all that oil come from the oil cooler or oil filter base, it look to me this is where it came from. help,help,help
Hi hh1045, I feel your pain, my 05 F350 6.0 4x4 Crew Lariat`s starter won`t activate.....
There`s some great help in the 2003 - 2007 6.0L Power Stroke Diesel forum so re post this in there: https://www.ford-trucks.com/forums/forum107/
Once you get the problem solved drop in and see who`s all in your local GA chapter: https://www.ford-trucks.com/forums/forum82/
