I just couldn't wait.....
Old Apr 23, 2009 | 05:21 PM
uncle.stosh's Avatar
uncle.stosh
I was so stoked about getting my new tires yesterday, but it's going to be a while until I get the Project Flareside up and running.
So instead of tripping over the rims and tires, I figured I throw them on my F2 Fiddy to see what they would look like.
They actually fit pretty good with only slight rubbing on the front fenders at full lock.
I think I'm going to keep them on here for a while until things get done on the other truck. Man, they ride NICE even without any weights on them at all! One thing I did notice is that my stopping distance has greatly increased due to the weight of the wheel and tire combo (~150lbs each).
Looky here. It's got BEEF written all over it:
Old Apr 23, 2009 | 05:54 PM
bashby's Avatar
bashby
You do get a lot of flywheel effect with the big tires. Did you get my PM about the 96 f250 steering column? I cant find one locally.
Old Apr 23, 2009 | 05:56 PM
Sycostang67's Avatar
Sycostang67
Thats looks awesome, it's amazing how much tire you can stuff under a truck with OEM wheels.
Old Apr 23, 2009 | 09:05 PM
Slyreaper's Avatar
Slyreaper
WOW that's sick.
Old Apr 23, 2009 | 09:11 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Damn that looks good!!
Ok, since were on the topic of wheels and Stosh was nice enough to already make a post for me...
I know it's not a truck, but it is still a Ford, I got the tires finally and had them mounted up yesterday. I put these on last night when I got home. The last pic was today at work, although the shade screwed me up, that and these are iPhone pics...
Thank you, we now return to our normal broadcast...
Old Apr 23, 2009 | 09:18 PM
uncle.stosh
Originally Posted by Slyreaper
WOW that's sick.
Dude, do you live in Swoyersville, Pa?
If so, I could probably hit you with a rock from here.
Old Apr 23, 2009 | 09:44 PM
Hometown Pride's Avatar
Hometown Pride
whats the PSI in dem der tires man? 120?
Old Apr 23, 2009 | 10:16 PM
86bigred's Avatar
86bigred
stosh those look awesome.is there any lift on your truck?
Old Apr 23, 2009 | 10:49 PM
Redneck1465's Avatar
Redneck1465
I wouldnt put them tires on the flareside I think they look great on that truck. I would leave them. By the way that mustang looks pretty sharp.
Old Apr 23, 2009 | 10:58 PM
Slyreaper's Avatar
Slyreaper
hahaha ya man. I cant believe I haven't seen your truck around. I would definitely have remembered it.
Old Apr 23, 2009 | 11:04 PM
FordNFishinLover's Avatar
FordNFishinLover
Mighty fine looking truck there man. Dig the tires!
Old Apr 24, 2009 | 01:55 AM
uncle.stosh
Nope, no real lift to speak of.
I did swap out the rear axle and springs last year out of a crew cab F350 though. Other than that it's stock (for now).
Old Apr 24, 2009 | 02:35 AM
IreallyLikeFords's Avatar
IreallyLikeFords
uncle.stosh, that truck looks awesome. leave em on there.
Old Apr 24, 2009 | 07:53 AM
uncle.stosh
I'm running 36psi in them right now but they will do 80psi and are load rated at over 4000lbs each!
With a set of beadlocks (which I will run on the Flareside) you can run them with 0psi on the trails. The side walls are that stiff.
I'll probably only air them down to about 10psi on the trails though. I'm too afraid of running them with NO air.
Old Apr 24, 2009 | 09:12 AM
LNF150's Avatar
LNF150
Stosh, that is Insane! Load rated at 4000 lbs per tire?!?! Jeez, Just how big of a boy are ya? But dang they look awesome on that truck!!!
