fuel pump voltage drop
Old Apr 23, 2009 | 02:39 PM
trent77969's Avatar
trent77969
I have a 2000 ford diesel and it flutters and acts as if it is starvin for fuel. I checked the voltage on the pump and I noticed the voltage drops off from 12.5 volts to 7 volts. What causes this?
Old Apr 23, 2009 | 02:50 PM
Kwikkordead's Avatar
Kwikkordead
Corroded connection somewhere.
Old Apr 23, 2009 | 02:52 PM
clintbonnie's Avatar
clintbonnie
Are you checking the voltage when the glow plugs are active? This will drop your voltage but not that much... I read about 11 volts when the glow plugs are on, with the engine running.. They stay for a couple of minutes, then the voltage will jump up to 14.3 after they turn off.
Old Apr 23, 2009 | 07:28 PM
12ozd's Avatar
12ozd
Drops from when ?
