I was wondering how much work would be involved if i wanted to swap out my 300 I6 and put a 351 M in instead. It is a 1979f150 4x4, with a 4 speed tranny. I just want to know what all has to be changed, on the truck
If you are going to put in a stock 351m, you are going to a lot of work for not much gain. If you are going to put in a stock 351m with xx,000 or xxx,000 miles on it, you are wasting your time and money.
You could freshen up the 300, add a few extras, and be back on the road quicker, for probably less money, and what money you do spend goes to making the engine run better vs. making it fit.
I did the opposite in my '79 Bronco. Frame mounts, throttle cable, radiator, bellhousing/tranny, radiator support may be different, exhaust (obviously, lol), and maybe a couple other things I'm forgetting. For a stock 351M, the 300 is about the same for HP and torque, IMO. 351M is a bit higher in torque, but a bit less in mpg. All in all, you can see it's not a simple bolt in affair. If you do do the swap, I'll gladly take those frame perches off yer hands.
there is quite a difference between the v8 and the straight 6, they drive completely different, the torque is different between them and the power curve i feel is alot more aggressive in the v8, i am fixing to do this swap except im putting a 302 in place of the 300-6 . . . my only concerns is wiring... as for the radiator, why would i have to change out the radiator from the 30-6 if im replacing a 302 in its pplace, the cubic inches are similar... should be sufficient right???
I need to get rid of a 351m (complete, carb to pan). It runs like a dream. Also have a 4/spd trans (granny). They are both out of a 78 F-250. I'm doing the reverse of what you are. If you are interested in some or all let me know.
