Exhaust Pics.
Old Apr 23, 2009 | 10:21 AM
azpowerstroke's Avatar
azpowerstroke
Exhaust Pics.
Hey i am wanting to put a full length exhaust on. I have a custom rear bumper and dont know if one will fit so those that have bigger exhaust could please post some pictures. Right now i have it where it comes out in front of the rear tire it sounds great but its making a mess of the whole side of the truck. Thanks
Old Apr 23, 2009 | 11:21 AM
powrstrkr's Avatar
powrstrkr
Here's one pic of mine, also showing my "new" mudflaps made from the BFG TA that shredded back in Dec 08. My system is aFe straight pipe all the way. Not sure if you can get just the tailpipe but I got it at DPPI. In addition to the tailpipe that hops the axle, you'll need an additional end piece that hooks to it to get you behind the tire. The end piece allows you to tilt it anyway you want. The tip is dual wall, 5in OD/4in ID stainless.Here's another one with the bed off while some body damage was being fixed. I never thought to take a pic of the exhaust from above - DANGIT!!
By the way, your 65 looks awesome!
Old Apr 23, 2009 | 01:13 PM
cowmilker08's Avatar
cowmilker08
Here's mine:
Cheap and it sounds as good as a $400 full exhaust system.
Old Apr 23, 2009 | 07:08 PM
azpowerstroke
Thanks powrstrkr.. my bumper is simular to that one just lower to the ground. it looks like it would clear
cowmilker08 did you use the stock set up around the axle?
Old Apr 24, 2009 | 10:35 AM
cowmilker08
yep, i cut out the cat and the muffler out and welded that pipe in place. total cost $60 for a peice of 10' pipe, but i only used 6 feet. the other four feet will most likely become a straight pipe for my IH 1206 diesel this spring.
